Sonny said:...........if you were limited to just one item, would you go for a TT - tube pre - SS amp or would you prefer TT - SS pre - tube amp?
interested to see some opinions..
Sonny said:how is a buffer different from a pre?
Vladimir said:If they need more power, then SS in power amp section. If they are high efficiency, then all valves.
DocG said:Vladimir said:If they need more power, then SS in power amp section. If they are high efficiency, then all valves.
That's cheating. *blum3* You must choose either or.
EDIT: OK, I was cheating too, suggesting a third option... *blush*
Vladimir said:DocG said:Vladimir said:If they need more power, then SS in power amp section. If they are high efficiency, then all valves.
I really don't mind hybrids at all. It depends on the design concept coming from the designer. If I find it interesting and sounds excellent, I'll certanly be interested. I've heard plenty generic all valve amps that were all too woolly and bland. If a hybrid can pull off that amazing rich raspy cello string purrr but still have a proper attack on drum instruments, I'll be emptying my pockets fast.
