- Aug 10, 2019
- 2,556
- 5
- 0
Hello Forum, after your help and a lot of research, I’ve received my new Panasonic 50vt30 and I have to say that is an awesome Tv: Good PQ: SD,HD,3D… , very good movement handling (even with my scene test, the opening secuence of the Dark Knigth)…. I am very pleased with this set.
There is something I’ve realised and for that I need your wise advice:
When you look very close to the screen (I am not mad I was checking the screen…😉) you don’t see a simple black screen, you see a black screen with very thin horizontal lines ( white-grey) moving vertically like if they where a very light interference . You don’t see anything but a wonderful picture at a normal viewing distance, anyone can tell me if this is a panel’s normal behaviour ? If not, is possible to modify some setting to fix it or I have to prepare to send the Tv to the store?
Good night Forum, Thanks for your help.
