how to setup a projector and screen?
hi every one i should be getting the keys to my house in the upcoming weeks and im a little stuck on how to get the screen and projector set up right,i have the optoma hd65 and a cheap motorised screen off ebay,should i set the screen first then the projector?and how do i get them square on with each other?i have used the software to work out how far back the projector should be, the wall im mounting the screen on is 11f wide the distance from the screen is aprox 14f and im installing a 92" screen.many thx
fix the projector screen and make sure its level then just make sure you buy an adjustable projector mount - fit the screen then move projector till square - just set a film playing and alter as needed.
you will need to alter the key stone and i tend to use either a little edge mask or a 1 click of overscan as sometims some tv has a slight rough edge
many thx m8 i have a ajustable celing mount,just need the keys now lol
