Setting up a high-power stereo system can be a daunting task. You want to ensure the highest sound quality, while also avoiding things like feedback. This guide will take you through setting up proper speaker placement for optimal sound. Follow this guide to have the best sounding party of the year.
Step 1
Ensure the proper speaker placement.
The first step is to ensure the proper speaker placement.
This will help with running cables from the stereo to the speakers, while also giving you an idea of the layout of the venue. The above diagram illustrates where to place speakers for the most optimal sound.
Step 2
Run the Speaker Wire.
The next step is to Run the Speaker Wire. To ensure the highest quality sound, make sure to use a very high-quality speaker wire.
[*] Connect the speaker wire to the back of each speaker.
[*] Run the Speaker Wire to the Stereo/Amplifier.
[*] Connect the speaker wire to each connector on the stereo/amplifier as detailed in the diagram.
Step 3
Test the System.
Now it’s time to turn on the amplifier and test the system. Plug the amplifier into a power source and turn it on. Depending on the stereo, it may have a test you can run. If not, turn on a song that will play through the full range of audio that you plan on presenting at the party. You will want to check that each speaker is playing.
After checking each speaker and confirming they all work; you are all set!
