The era of 4K Ultra HD Blu-ray Players has dawned upon us. A 4K Ultra HD Blu-ray Player affords you consistently high-quality videos without the hassle of buffering on internet-based platforms. The 4K technology gives you four times as many pixels as your regular 1080p HD video. In fact, you can even upgrade your dusty old DVDs or HD Blu-rays to the 4K format before enjoying your favorite movies and TV shows. This tutorial will walk you through the steps required to set up a 4K Ultra HD Blu-ray Player.
Step 1
Connect the power cable
Connect the 12-volt power cable to the port at the back of the player. Your player can now be switched on.
Step 2
Connect the HDMI cable to your player
Connect one end of the HDMI cable to the Blu-ray player. This will help connect your player to the television screen.
Step 3
Connect the HDMI cable to your TV
Connect the other end of the HDMI cable to your television. Now, your Blu-ray player is connected to the TV.
Step 4
Eject the disk drive
Press the ‘Eject’ button on the front of your player. This will open the disk drive so you can insert your Blu-ray disk.
Step 5
Insert your Blu-ray disk
Put your favorite Blu-ray disk in the drive and press ‘Eject’ again. This will close the disk drive. Your disk is now ready to be played at a breathtaking resolution.
Now, you can enjoy that Avengers: Endgame 4K Ultra HD Blu-ray disk that has been lounging in your living room for weeks.
