SteveR750 said:System matching, surely.
Yes, but just trying to put a little "meat on the bones".
Though it has to be born in mind what a wise old bird has said on here - "Why drive something like a Golf...........".
Covenanter said:I wonder if you might do best by upgrading the speakers? I'm one of those who thinks that speakers are the most important part of a system (as long as you have a decent source) and if you like MA speakers then maybe look at the RX8s?
Chris
plastic penguin said:Nope, not getting rid of my Leema, interested in seeing how close one could get without the amp losing its essential qualities... what speakers and source.
So what's the bigger difference? Vast or huge?SteveR750 said:The only Class A amp I have ever liked came out of Milton Keynes in 1986. I suspect it's class A/B when set to Hi Gain.
I can't comment on a tube hi fi amp as I've never heard one, but there is a vast difference between transistor and tube guitar amps, in fact a huge sonic difference in valve class A and A/B, but then they are for a lot of the time designed to sound good when clipped, which a SS amp doesn't naturally.
plastic penguin said:However, its achilles heel is female vocals like Adele, Joss Stone or Simon & Garfunkel (remastered), Beatles (remastered) and it sounds a little cold.
Macspur said:Any chance of getting a listen to some Harbeths PP?
Mac
CJSF said:Class A, B XYZ!!! . . . In all my years, it has never been a consideration, maybe that because I have always been a valve man . . . the bottom line has always been, what does the sound do for me? PP, you are looking at the greener grass over the fence . . . some of your music is to your liking, some not so good, may I respectfully suggest its the sours/material and treatment there of? You seem to me to be going around in circles rather than accepting that there are differences that cannot be resolved easily.
You note in your signature, "loads of cable" . . . why not back track, you might find a combination that is more to your liking and dont ignore the cheap stuff! Check through your system, the little points, cable connections etc., by the way, I believe . . . 'I know' cable can be direction, keep this in mind. I was getting unhappy with my sound a couple of weeks ago, worked through all connections and variables, finally found one of the speaker stand floor spikes was not grounded properly, all is now sweetness and light.
Reading these pages, it seems to me, often, a good sound is found, but there is always an itch . . . trying to scratch that itch throws everything off. The road back seems hard to find for some?
Dont bother with the music that is not engineered to your liking . . . :doh: I do this all the time with my preferred digital source, dip toe in, no, not my type of music, or, I dont remember it like that, move on quickly.
CJSF
Electro said:Also I think people mistake the effects of class B crossover distortion as brightness or a cold sound so when they hear a class A or high bias class AB amplifier and it sounds smooth and detailed without any harsh grainy distortion the sound appears warmer or more ear friendly for want of a better description .
Changing speakers for others with a rolled off top or recessed mid can lessen some of the bad effects of class B crossover distortion but never eliminate it and only leads to frustration and disappointment in the long term IMO . .![]()
plastic penguin said:CJSF said:Class A, B XYZ!!! . . . In all my years, it has never been a consideration, maybe that because I have always been a valve man . . . the bottom line has always been, what does the sound do for me? PP, you are looking at the greener grass over the fence . . . some of your music is to your liking, some not so good, may I respectfully suggest its the sours/material and treatment there of? You seem to me to be going around in circles rather than accepting that there are differences that cannot be resolved easily.
CJSF
No I'm not chasing my tail. As we're all hi-fi nuts, it's good explore (other) possibilities. In the main I am very happy with my set-up - this thread has confirmed, mainly, that my system's weak link is the speakers. Like all of us - or most anyway - I'm trying to push the very feasible limits of my kit, and discovering how far one can manipulate the presentation.
Can't really ever seeing myself buying a valve or a Class A amp... just not practical: They tend to use more electricity than the average SS amp, proned to overheating (my amp is used between 4-6 hours most days), and I think those reasons are more of a compromise than my one or two current issues.
No doubt once I have the money then the RS6s will be history. As I mentioned from day one, over two years ago when I purchased the Leema, it'll act as a catalyst or hub in which my whole system will be built around. The Pulse has too many strengths to discard...
plastic penguin said:Can't really ever seeing myself buying a valve or a Class A amp... just not practical: They tend to use more electricity than the average SS amp, proned to overheating (my amp is used between 4-6 hours most days), and I think those reasons are more of a compromise than my one or two current issues.
CJSF said:plastic penguin said:CJSF said:Class A, B XYZ!!! . . . In all my years, it has never been a consideration, maybe that because I have always been a valve man . . . the bottom line has always been, what does the sound do for me? PP, you are looking at the greener grass over the fence . . . some of your music is to your liking, some not so good, may I respectfully suggest its the sours/material and treatment there of? You seem to me to be going around in circles rather than accepting that there are differences that cannot be resolved easily.
CJSF
" . . . The Pulse has too many strengths to discard . . . " I'm certainly not saying dump the system or that it is poor, far from it, I suggested 'back track' on what you have in stock. I found this very rewarding last year, saved me money and frustration, giving surprise and pleasure on more than one occasion with subtleties I had missed . . . :?
As for valves overheating . . . thats a misconception I have heard many times . . . by their nature of operation, they 'look and get warm', drive them hard they get very warm . . . some more than others? . . . I have never had problems with 'overheating' . . . I've seen capacitors and resistors 'burn out' in 'solid state' circuits!
CJSF
Electro said:Many people say that class A amps sound warmer than other type of amps but this has not been my experience , it might just be a psychological effect because class A amps are warm or hot to the touch
The only way to get that class A crossover distortion free sound is with a well designed class A or high bias class AB amplifier , this is why people like myself and CNO are constantly recommending these types of amplifier .![]()
Covenanter said:PS WRT Adele the recording of "21" is to my mind (ears) very harsh and metallic (I suspect it has been compressed to make it sound good on cheap equipment) and I would never judge a hifi on the basis of how it sounded. In some ways it sounds better on my car's CD player than on my hifi!
What other female voices does it struggle with?
Chris
plastic penguin said:So if valve amps aren't warmer than SS why choose them? What makes them stand out from the SS crowd?
