- Aug 10, 2019
- 2,556
- 5
- 0
I'm off to audition some Naim equipment in a couple of weeks.
I'll be listening to CDPs - CD5i, CD5XS and CDX2 and amps - Nait5i, Nait XS, SuperNait & NAC200+NAP200 Combo.
The idea being that I will establish my reference for auditioning other systems as well as helping me to set my budget. I'm starting with Naim because I am so blown away by the sound of my Uniti.
I'm now doing my homework before I go. A couple of questions:
1. How should I establish a reference speaker for trying these different systems, do I just pick one that I am familiar with (Neat Motive 3's for example) and then stick to the same speakers whilst I try the out the different electronics. The advantage being that I am comparing the difference that the electronics make. Or should I try price appropriate speakers for each system? Assuming that some of the more expensive gear will only really show the benefit with more capable speakers.
2. To those of you who have tried Naim before - how big a difference between the systems will I notice, will it be subtle or obvious? How much music should I take to try them out and how long does one normally listen before making a call? (I've not bought new HiFi, except the Uniti that didn't really have anything to compare, for about 15 years)
3. I then have to go to other dealers to listen to some of the suggestions that you guys have given me for comparisons. There is likely to be a gap of a couple of weeks before I go to the next place - any hints on how to make this comparison when the systems are not side by side?
I know these questions sound a bit naive, but buying a complete new system, rather than upgrading one bit at a time, seems to me to be very complicated, and I don't want to make a mistake. This system will be the base which I'll live with for the next 15 years at least.
Thanks for your help!
David
David
