hugo57 said:Quite a late reaction to this post but what I want to say fits perfectly here, so I thought I'd rather not open another thread...
I had exactly the same experience yesterday... 🙂
Was reading the speaker cable test in the latest issue where directionality was also mentioned. This made me check my cables (using the FLX-SLIP 14/4, unterminated) and I noticed that the arrows on the front right cable are pointing in the wrong direction (speaker to amp). I decided to turn the cable around although I didn't expect it is going to make any difference. But, I thought, it can also do no harm. And to my great astonishment, it did make a big positive difference. :O
Exactly as mentioned in another post above, that "slight but noticeable sharpness, or harshness" disappeared from the sound I hear from many of my recordings. I'm absolutely positive I'm not just imagining it. Can't hear the difference in equal measure in all recordings but it is particularly noticeable in the Paper Airplane album of Alison Krauss & Union Station. This sounded pretty thin (lack of bass) and harsh before, now it's full-bodied and clean. The sound I hear now is equally dynamic (if not more), detailed and crisp but without that sharp harsh edge.
I changed nothing else in my setup and I'm listening to the same recording (CD quality FLAC) so I assume the difference can only come from reverting the cable direction. Maybe if both cables (left and right) were pointing in the wrong direction the difference would not have been this big. The amp and speakers might also have an influence (mine are a Pioneer SC-LX 83 with Focal Aria 926 fronts). Anyway, I'm very happy with this outcome... :bounce:
The only conclusion I can draw from this is: do respect those arrows on your cable, if there, chances are you'll get better sound.
CnoEvil said:hugo57 said:Quite a late reaction to this post but what I want to say fits perfectly here, so I thought I'd rather not open another thread...
It is quite possible that you cleaned and tightened the connection as a result of changing it round. The best way to check this, is to change it back and see if the sound changes reverts to what it was.
