oldric_naubhoff
- Mar 11, 2011
- 23
- 1
- 0
altruistic.lemon said:Secluded area in the UK? Where's that, then?
Try Daley River or Katherine in the NT before you carry on about secluded.
and who's claiming I live in the UK?...
Inter_Voice said:Any examples? Normally I don't read seriously on ratings from magazines but comments from forum/discussion groups over the internet globally have much more weight when I decide what to buy. One needs to use some sense to filter out what had been written in the forum discussions. Some feedbacks are just unprofessional but a large number of them are quite experienced in audiophile.
altruistic.lemon said:Where do you live?
lindsayt said:What do you do when your dealer stocks 50 different flavours of the same thing?
MoData said:The alternate to demoing is just getting a 5* system and sticking to that for a few months, and liking what you have, rather than trying to find faults in it and trying to get the next best thing. To a certain degree, you'll get used to what you have and like it.
TheHomeCinemaCentre said:If sound and picture quality are a major consideration then a demonstration is essential in my book.
chebby said:lindsayt said:What do you do when your dealer stocks 50 different flavours of the same thing?
Ooh I know... cut & paste a triple spaced list of the same 40 year-old junk in answer to every single query?...
Excitable Boy said:TheHomeCinemaCentre said:If sound and picture quality are a major consideration then a demonstration is essential in my book.
Surely this is always the case ????
plastic penguin said:TheHomeCinemaCentre said:There is no doubting the benefit of forum comments, if nothing it can alert you to products you may never have considered. Ultimately though if you are concerned about performance only you can decide what you like and that should be done in comparison.
You can go into any wine shop, pick a £20 bottle of wine and be happy with it. Try two and one will be more pleasing.
Please forgive my ignorance: If we are, as you know as a dealer, looking to spend hundreds or even thousands of pounds on upgrading or as a starter kit, so comparing it to a couple of bottles of wine is crass.
TheHomeCinemaCentre said:plastic penguin said:TheHomeCinemaCentre said:There is no doubting the benefit of forum comments, if nothing it can alert you to products you may never have considered. Ultimately though if you are concerned about performance only you can decide what you like and that should be done in comparison.
I did not intend to be crass, I was trying to show that if you do not compare things you can be quite happy with your first choice - hence people buying from review and then glowing about it when they are on-line.
Most wine at that price is good in the same way that if you buy a £1000 amplifier or a £1500 TV it will be good. Similarly with cars - plenty of people do not test drive the car they buy and if they do they rarely test drive the competition. How can you know that the seats are comfy unless you try two. As I see it you just wont know if it is the best for you without comparison, maybe I have the wrong end of the stick on this.
plastic penguin said:A kit made up of award winners doesn't guarantee a wonderful sound. It can, in certain circumstances, sound 'orrible. This is something I've always advocated, unless, of course, the set-up was done in your living room.
plastic penguin said:Mmmm, you need to try before purchasing, like the seats. As a reputable dealer I thought you'd be a keen supporter of shop and home demos.
the record spot said:plastic penguin said:Mmmm, you need to try before purchasing, like the seats. As a reputable dealer I thought you'd be a keen supporter of shop and home demos.
He did mate. Nick's just pointing out that a lot of people buy blind, or on the strength of the brand, without necessarily sitting down and comparing, like for like, with other product.
CnoEvil said:the record spot said:plastic penguin said:Mmmm, you need to try before purchasing, like the seats. As a reputable dealer I thought you'd be a keen supporter of shop and home demos.
I also suspect he is saying (and I could be wrong), that it is all too easy never to look outside the "usual suspects".....and very often, the answer lies a bit off the beaten track. I refer to makes like Paradigm, Icon Audio, Sugden, Unison Research, Pure Sound, Lavardin, Pathos, Peachtree and Electrocompaniet....I suspect most people never try them, and in fact, may not even be aware of them. They may not be the answer, but (as Nick says) you will never know without a comparison.
You left out Wilson Benesch, Leben, Magnepan (don't explode, PP), Martin Logan, Bryston, Densen, Nottingham Analogue, T+A, Lavardin, Atoll, Hegel and many, many more.CnoEvil said:I also suspect he is saying (and I could be wrong), that it is all too easy never to look outside the "usual suspects".....and very often, the answer lies a bit off the beaten track. I refer to makes like Paradigm, Icon Audio, Sugden, Unison Research, Pure Sound, Lavardin, Pathos, Peachtree and Electrocompaniet....I suspect most people never try them, and in fact, may not even be aware of them. They may not be the answer, but (as Nick says) you will never know without a comparison.
plastic penguin said:Looking at the "usual suspects" is fine: Don't forget I bought CD73T (Award winner), RS6 (5 star), Pro-ject Xpression 1 (award winner), but I never purchased these without a darn good dem with my existing equipment. And in the case of the speakers and CDP the shop let me home dem Rotel RCD-06 and MA GR10, in addition to a long and laborious shop dem.
Look how long I keep my gear: To me that speaks volumes (excuse the pun) because if I wasn't happy I'd take it straight back - no way would I live with something I'm less than 100% happy with.
altruistic.lemon said:You left out Wilson Benesch, Leben, Magnepan (don't explode, PP), Martin Logan, Bryston, Densen, Nottingham Analogue, T+A, Lavardin, Atoll, Hegel and many, many more.
CnoEvil said:plastic penguin said:Looking at the "usual suspects" is fine: Don't forget I bought CD73T (Award winner), RS6 (5 star), Pro-ject Xpression 1 (award winner), but I never purchased these without a darn good dem with my existing equipment. And in the case of the speakers and CDP the shop let me home dem Rotel RCD-06 and MA GR10, in addition to a long and laborious shop dem.
I would say that you are starting to find out the merits of the "less usual suspects", with the purchase of the Leema and the exploration of the Totems. 😉
altruistic.lemon said:You left out Wilson Benesch, Leben, Magnepan (don't explode, PP), Martin Logan, Bryston, Densen, Nottingham Analogue, T+A, Lavardin, Atoll, Hegel and many, many more.CnoEvil said:I also suspect he is saying (and I could be wrong), that it is all too easy never to look outside the "usual suspects".....and very often, the answer lies a bit off the beaten track. I refer to makes like Paradigm, Icon Audio, Sugden, Unison Research, Pure Sound, Lavardin, Pathos, Peachtree and Electrocompaniet....I suspect most people never try them, and in fact, may not even be aware of them. They may not be the answer, but (as Nick says) you will never know without a comparison.
