How do you know if you have clean or dirty electric
Well, it's possible to buy or hire a device able to turn noise on the mains into sound, thus enabling you to identify whether there's a problem...
Thank you Andrew I have a Tacima lead, when fitted I did notice sound improvement but no picture gains,
Also should my amp be plugged into it or direct from mains,thanks
Any viable alternatives to the Audio Prism in the UK? There's a Belkin gizmo that seems similar.
Andrew Everard:I'd plug your amp straight into the wall.
Could you explain why this is so please? I'm sorry If this has been discussed b/4,
piobob:
i think its because some audiophiles belive it strangles or restricts the power to the amp that in turn afects the output of the amp in terms of power and changes the amps charicter.
EDITED BY MODS to remove potentially dangerous advice
piobob:Andrew Everard:I'd plug your amp straight into the wall.
Simply that I've found most amps sound better when powered this way, rather than via mains filters/conditioners.
Ah Right, thanks. I'll take mine out of the Tacima later and see if I notice any difference. 🙂
piobob:Ah Right, thanks. I'll take mine out of the Tacima later and see if I notice any difference. 🙂
did you notice any differance,thanks.
nodnarb4444:piobob:
EDITED BY MODS to remove potentially dangerous advicewasnt really ment as advice as i didnt recomend it be done,sorry for any confusion
simoncar:piobob:Ah Right, thanks. I'll take mine out of the Tacima later and see if I notice any difference. 🙂
did you notice any differance,thanks.i found my tacima made masive diferance to my tv but not so much to audio so i have gone amps wall and tv via tacima.
Erm, sorry I haven't watched the box yet and going out tonight so will have a go tomorrow(if I stay in
) and let you know what I find
should we be plugging our expensive amps into surge protectors, not direct into the wall sockets.
