How do I transfer Contacts from an HTC Android to an iPhone?
6th.replicant
294
I've ordered an iPhone.
Anyone know how I transfer my current phone's - an HTC Android - Contacts to the iPhone? (My computer is a Mac, OS X 10.8, which I've never synced with the HTC.)
Ta 🙂
You should be able to:
1) Go to your contacts on the HTC, choose import/export > export to storage and save them to 'Phone'
2) Put your HTC phone into disc-drive mode and connect it to your computer
3) Copy the .vcf file from your HTC (which will appear on your Mac as an external hard drive)
4) Set-up your mail account on the iPhone
5) Send that mail account an email with the .vcf file as an attachment
6) Open the mail, click on the attachment and tap 'Add all contacts'
Et viola, as they say in the section of the orchestra just behind the violins
Or, if you have a Googlemail or Gmail account on the HTC, and you contacts are stored there you could just set up the same account on the iPhone using the Exchange mail option, and it should pull through all your contacts.
Done steps 1-3, then opened the .vcf file on my Mac, but only 50% of the phone's contacts are in the .vcf :?
Have I done something wrong? 😳
Is it 50% contact names missing or 50% contact information tho all the names. Whilst the phone stores all info, the sim card only stores one number for each contact. Sorry if this is a red herring since I know my plaice. 🙂
Could it be that some of your contacts are stored on the phone's memory, and some on the SIM? I'm not very familiar with the HTC phones, so wouldn't know how to check this, or copy them all to one place, but I am sure someone on here can advise.
Via Mac / Safari, I've just logged into my Gmail account, peeped in its Contacts and all of my HTC's contacts are listed, which is kinda spooky - "how did they get there?" 😱
So, I've now synced the Mac's Contacts with Gmail's and, in turn, I'm assuming the iPhone will sync with the Mac's Contacts... correct?
Ta for advice, folks 🙂
Just in case anyone else needs to transfer an Android phone's contacts to an iPhone, here's the solution:
As discussed above, load the Android phone's Contacts into your Mac's Contacts / Address Book via Gmail.
Next, open Contacts / Address Book on your Mac, click on any single contact to select it, go to Edit > Select All (Command-A) to select all contacts.
Go to File > Export > Export vCard, and then save this file on your Mac desktop.
Send an email to yourself with this file attached.
Open the email on your iPhone and tap the attachment to import the contacts :grin:
Oh, and in future, only edit / add to Contacts on your iPhone, not your Mac. If iPhone's Contacts is amended, iCloud will auto update your Mac's - but not vice versa, for some reason :?
Export contacts from HTC to vCard and then import the file to Gmail. And then launch iTunes and connect iPhone to Sync contacts.
I suggest you use google account to export your cotacts to a vcard format, and import to iCloud. If you found this is difficult, you can use some third party software to save your time. Some of software not only support contacts but also music and photos, even text message.
If you have a Googlemail or Gmail account on the HTC, and you contacts are put away there you could simply set up the same record on the iphone utilizing the Exchange mail choice, and it ought to draw through all your contacts.
Inserting spam into a quote from another user - nice one! Are there no depths to which you idiots won't stoop?
