- Aug 10, 2019
- 2,556
- 5
- 0
I am in the process of buying a Home Cinema kit and planning the installation myself (with an electrician coming to do the actual wiring). The kit will comprise of:
- Pioneer Kuro 5090
- Sky HD
- PS3 (for games and Blu Ray)
- Receiver – Denon1909
- Speakers – B&W MT30’s
I will definitely be getting the Pioneer TV but am happy to listen to people for advice on receiver and speakers.
Amp – My budget was originally £1k for the amp but the Denon 1909 looks great for half the price. The Onkyos have had good reviews but I am worried about their overheating issue (I will not have a cabinet to put it in, it will be out in the open) as well as PS3 compatibility. Can a Pioneer amp do a better job than the Denon?
Speakers – I like the look of the MT30’s and performance looks good as well. I need the speakers to be small in size. The other speakers I have seen are the ones that match the Pioneer TV (the long ones where the front speakers are same height as the screen) and the centre speaker which does under the screen – are these any good?
In terms of the system, am I proportionately spending the right amounts on the various items (I plan to use it mainly for sports and movies – not much music).
In addition to the above, I will also be designing the wiring myself. I will set it up so that all the wiring is channeled behind walls. Should I be putting any extra wires in to “future proof” – (this is a one room system so not sure if I will bother with cat5e) – I was thinking of connecting an extra HDMI cable in case I add anything to the system. Finally, can I use the speaker wires that come with the s[peakers or should I buy them separately (and if so, how much per metre should I be looking to spend for a system such as the one above).
- Pioneer Kuro 5090
- Sky HD
