CnoEvil said:Hi there, and welcome to the forum.
Try again, and we should be able to give some insight.
Your choice will depend on the quality / sonic balance of the amp you're using and personal taste.
Nothing is perfect. They all have their foibles and shortcomings. It is finding the one that suits you. Just because it is a dedicated AV system, there's nothing in the rule book to say you can't use hi-fi speakers, for example.wackyraces said:hi thanks for the feedback. for clarity here i am wanting to build a custom home cinema room using a home cinema design specialist. they recommend a whole load of products i have never heard of but assure me they are built for home theatre rooms. on the other hand. i am speaking to audiot the hifi shop in manchester who say i am better using hi-fi separates. obviously both want me to buy the equipment from them. my thoughts are that it is better to use robust "separates" manufactures of well known hi fi equipment rather than a home cinema manufactures equipment if i am to obtain the best sound.
I have to be honest, it's been a long time since I've heard a REL I like, particularly for home cinema. Thankfully, there's plenty of choice out there. Do you have more money than sense? There will be plenty with an opinion, but only you can answer that question with any relevancy - you know how often you watch films, and you know how much enjoyment you (and maybe others) get from them, so you will know if it is worth the investment. Many people will spend this sort of money on a car (sometimes twice as much), which loses 50% of its value as soon as you park your rear in the driver's seat.i am only interested in watching movies. the equipment i am thinking if buying is listed below. as i am not any kind of expert i would appreciate honest feedback as to whether this system of separates has the wow factor or whether i have more money than sense:
sony vpl-vw500es projector
yamaha cx-a5000 pre amp and mx-a5000 power amp
oppo blu ray bdp-105eu multi region with roku streaming
kef reference 205/2 floorstanding
kef reference 204/2c centre speaker
kef reference 206/2ds dipole pair
REL subwoofer 528se
Speaker choice seems fine for the room size.the room is 17ft by 17ft
wackyraces said:in answer to your questions:
- total budget - 25-30k (equipment only)
- Will you be using the system for 2 channel, and if so, what would your percentage split be, between AV and 2 channel - being a complete layman i haveno idea what that means. i will be using the system solely to watch movies not for music
- What sort of sound do you like ie. Smooth but detailed, or more forward and exciting - unsure but i would opt for forward and exciting - want to be able to feel the movie and hear gunshots or loud bangs all around the room and also want a very strong bass
- Will you be auditioning the choices you have - vital given the money you will be spending.- yes definitely. its too much money to be spending without listening and watching first
might try and demo the arcam amps you mentioned
i have tried the R series which sounded great but i need to make the comparison with Kef Reference.
now what about the home theatre brands such as Procella, M&K, Triad and Artcoustic? i have never heard of any of these but they are all very well known speaker brands in the Home Cinema markets. is it better to buy speakers dedicated to home theatre use or is it better to use high end stereo speakers? i have googled different forums but still havent found a satisfactory answer to this question, which are the better speakers for a dedicated home cinema room?
CnoEvil said:The fact you are not interested in music, in some ways makes things a little simpler.
I can only advise in my sphere of knowledge, which is around the brands I've mentioned.......I'm not familiar enough with the dedicated home theatre brands (like M&K).
If it was my money, and 2 channel wasn't an issue, I would go for the best Centre in the range (eg.204/2c), and a really decent Sub (Velodyne DD Range or something from JL Audio). I would also save a little money on the Front L&R (eg 203/2). Nb. Around 60-65% of the info comes out of the centre channel.
IMO You will be delighted with the new Arcam amps when matched with the Refs, but if you don't go this route, you should try to hear Bryston. In this system you are putting together, the amps will make or break the sound you get, especially with the Refs.
Please let us know how you get on
Cno
EDIT. There is good advice above, though it would be good to hear from Clinton333 who has Kef Refs (203/2 + 202/2c) with Arcam (AV888 / P777) and a decent sub (B&W DB1). http://www.whathifi.com/forum/your-system/system-updated-2013
clinton333 said:I can also only speak highly of the Oppo BDP 105... extremely versatlite if you ever do feel the need to use your awesome system for 2 channel
ellisdj said:Personally I would spend more on the amplifier and consider that a higher priority than reference speakers.
Reference speakers under driven will likely sound worse than great speakers off a great amp thats driving them cleanly
The new Yamaha Power Amp looks like a good amp - but if you look inside you have 1 transformer and 2 Capacitors (allbeit monsters) feeding only 2 main channels of amplification thats divided into 5 / 6 channels when you look at it. I am not an expert but to me the design has compromsies becasue of cost, size and the amount of channels its powering
Now in comparison if you are only running 5 channels then the Bryston 9BSST2 - has a dedicated amplifier section per channel with its own transfomer per channel - not many power amps have that that makes it quite special. Like mini mono blocks really - its a chunk of your budget at £8k
Or go all out and get a JL Audio Gotham but again that will much a huge chunk of your budget £10k - thats why the monolith is so highly rated its bloody cheap at £500. The Gotham would be amazing - hope they have one to see / hear at Bristol show this year
