HMDI Trouble
HI
I am trying to connect my Sony Bravia 40d3500 to a sony dvd player rdr-gx350 through HDMI i have been in both set ups and turn on the HMDI i then go to the tv set up and do the search for a new device but it comes back nothing found , please could i have some help
jason
Cant even spell it right oops
HDMI
It's my understanding that any source plugged in via an HDMI socket does not need to be 'found' by the TV. You should be able to turn the TV on, select the HDMI input and play a DVD.
Cheers,
Cofnchtr.
oh right so it makes no diffrence to picture quality as long as the HDMI cable is in i will get upscaling from the dvd player to 1080p ?, i just thought by reading mauals they had to interlock to get best results.
Indeed HDMI should take care of everything and should link your TV and DVD player through Sony's Theatre Sync (universally known as HDMI-CEC). Both your 40D3500 and RDR-GX350 should upscale any signal to 1080p so you should not have any problems. As far as I am aware 1080p should be displayed in the top right corner of your screen when the DVD player is selected.
Hope this helps. Kind regards, Darren
