- Aug 10, 2019
- 2,556
- 5
- 0
Hello, your help much appreciated...
Does the integrated to power amp interconnect need to be the same as you'd use on a cd connection? It's only feeding the bass part of the bi-amping, isn't it?... so isn't that omni-directional and any bog standard interconnect will do? I have drawers full of them.
After a long time thinking of upgrading, I took the plunge on a used Tag McLaren set up. I'm very happy but am wondering if I'm losing out now with the previous system interconnects?
I have two higher quality interconnects, using Chord Cobra (original!) and Atlas Equator (old version not sure which). Equator between integrated amp and power amp, Cobra between cd and streamer.
If I'm wrong about the integrated to power amp scenario, I'll need a third interconnect as I'm currently swapping between cd and streamer, which is annoying.
System is Tag 60i and 60P with Tag CD20R, Kef Reference 2.2's and a CA StreamMagic 6 streamer. Interconnects as above.
Thanks very much in advance!
