p_m_brown said:Appreciate your thoughts. Must say, through my Leema dac, I'm really enjoying the sound, so much so that I flogged my CDP!
Totally agree about the CDP: waste of space. DAC and streaming (from PC/Mac/streamer) is where it's at.
Overdose said:the record spot said:Overdose said:jjgreenwood said:I wouldn't use sonos, what would your opinion be of my tv as a source - it outputs PCM.
I don't see a problem.
It is if you want a specific mastering, say, that's only available on an HD Tracks FLAC release, or 2L, or similar. Otherwise, I stream some music occasionally through the TV, or off my PS3 from the Music Unlimited source. Sounds fine. No issues or noise.
Yes, but the media player in the TV (or any other equipment for that matter) converts the files to PCM and outputs PCM to a DAC, so I don't see the TV outputting PCM as a probem, or have I missed something? Surely that's the way it should work.
Edit: I see now. the Sonos being the problem and not the TV. I meant the TV, I guess you meant the Sonos.
Overdose said:Yes, but the media player in the TV (or any other equipment for that matter) converts the files to PCM and outputs PCM to a DAC, so I don't see the TV outputting PCM as a probem, or have I missed something? Surely that's the way it should work.
the record spot said:Exactly, or at least, normally, the TV wouldn't be - I've streamed via my Sony telly without a hitch many times. However, it's restricted to PCM, so if you want FLAC, or whatever, you lose out.
matt49 said:p_m_brown said:@Matt49
interesting thoughts about the Sonos being a "dirty" source. Do you mind elaborating as Ihave not had the benefit of your experience comparing it to other sources?
FWIW I find it works extremely well with a decent dac and could be a great solution for the OP.
OK, on the Sonos question (though I know the OP has already excluded it, but @p_m_brown and @Overdose both expressed surprise at my earlier statement that I found Sonos to be a "dirty" source).
I have two sources piping ALAC files into my M-DAC: (1) PC via USB and (2) Sonos ZP90 via digital coax (FWIW: the coax cable is Chord Co Prodac Pro VEE3 interconnect, which retails at £65 but I got "free" with some other kit). Using the M-DAC's remote, I can switch instantaneously between the two, and I've spent about a week doing this, lining up the same tracks in parallel and switching between them over and over again.
OK, so only my ears and brain making the judgements, but I got a pretty consistent picture. Source (1) is OK, but (2) has smeared leading edges to the notes and an overall grainy sound, especially (but not only) at high frequencies. In addition to listening through the amp and speakers in my signature below, I've also spent a lot of time listening through Grado SR325is plugged into the M-DAC: same result.
I also spent two days comparing Sonos > M-DAC > Naim Superuniti against USB memory stick > Naim Superuniti: same result.
Why should this be? The theory is Sonos spent loads on the interface, and the after-sales service is excellent IME, but the electronics inside the (rather nice) boxes is cheap and nasty. That's not just my view. Go on to the Sonos forums and you'll find plenty of people who aren't happy with the sound.
So now I've given up using Sonos as a hi-fi source; it's just not a pleasurable experience. Problem is: I love the networking capacity and interface of Sonos, which are truly class leading IMO. (And also my family love it.) So I'm in a bit of a quandary about what to do with the new "big" system I'm building downstairs in the living room. Linn Majik DS is a nice, though pricey thought (hence my earlier recommendation to the OP.)
I hope that sheds some light.
andyjm said:matt49 said:p_m_brown said:@Matt49
The ZP90 has relatively poor jitter performance (north of 250pS RMS if I recall correctly), though I am not sure I would classify that as 'dirty'. This is an order of magnitude worse than premium quality streamers. This used to matter, but these days most DACs have some form of jitter mitigation circuitry, and I am surprised that the M-DAC is sensitive to this. Any decent design of DAC shouldn't depend on the stability of the input S/PDIF stream for its local clock and therefore sound quality of a decent DAC should be independent of the streamer used.
matt49 said:Go on to the Sonos forums and you'll find plenty of people who aren't happy with the sound.
matt49 said:Also presumably there are other sources of jitter than the clock in the Sonos, e.g. the PSU.
The_Lhc said:matt49 said:Also presumably there are other sources of jitter than the clock in the Sonos, e.g. the PSU.
And the fact that you've convinced yourself that Sonos is no good, so you're hearing what you expect to hear. I bet you couldn't reproduce the results blind.
matt49 said:p_m_brown said:Appreciate your thoughts. Must say, through my Leema dac, I'm really enjoying the sound, so much so that I flogged my CDP!
The_Lhc said:matt49 said:Go on to the Sonos forums and you'll find plenty of people who aren't happy with the sound.
I spend all day on there
The_Lhc said:and I've not noticed anybody complaining about the quality, quite the opposite in fact.
matt49 said:Try googling Sonos forum modification or mod or similar. That'll turn up a few. You'll also find some similar discussions on other fora.
matt49 said:The_Lhc said:matt49 said:Go on to the Sonos forums and you'll find plenty of people who aren't happy with the sound.
I hope you don't mean that literally 😉
The_Lhc said:matt49 said:The_Lhc said:matt49 said:Go on to the Sonos forums and you'll find plenty of people who aren't happy with the sound.
Sure, why not? I sit at work all day, typically with not much going on and I idle away the time bouncing around between here, twitter, the BBC, New Scientist and the Sonos forum, amongst others.
Overdose said:Try again using any other name brand audio equipment and you're likely to get the same sort of web pages from other paranoid people who have convinced themselves that a better power supply, for example, is the cure to some percieved design flaw by the original manufacturer.
Why is it that amateur DIY hifi types seem to know better than the manufacturer, who presumably has a competent R&D department?
Anyhow, perhaps you have heard a difference, but I'm not sure that DIY modding forums is the best evidence for it.
matt49 said:andyjm said:matt49 said:p_m_brown said:@Matt49
yes, I understand that the DAC reclocks the signal from S/PDIF, but presumably this is still less optimal, at least as far as clock jitter is concerned, than piping the signal through asynchronous USB.
Not looking to disagree, just trying to understand. :doh:
Overdose said:the record spot said:Exactly, or at least, normally, the TV wouldn't be - I've streamed via my Sony telly without a hitch many times. However, it's restricted to PCM, so if you want FLAC, or whatever, you lose out.
No, but the TV is capable of playing FLAC files as far as I understand.
andyjm said:In an ideal world, the clock used to step the samples through the D2A chip in the DAC would have zero jitter, and be mounted next to the D2A chip on the DAC circuit board. Arguably the worst place to put it is in a separate box, and embed the clock signal in the audio data, then send it over a bandwidth limited link (S/PDIF) to the DAC.
The problem with a local DAC clock and S/PDIF is flow control. If you use a local clock in the DAC to drive the D2A chip, unless the data arrives at exactly the right speed down the S/PDIF link you get underflow or overflow of data. Async USB solves this problem as the DAC can control the speed at which data arrives. So in answer to your question, async USB is better - all other things being equal.
To be honest, given that a streamer takes up a couple of square inches of circuit board real estate, there is no good reason for not having the DAC and the streamer co-located. Thats how I would do it.
Getting back to Sonos, I personally dont think there is anything wrong with Sonos at all. If your DAC is dependent on the clock stability of the incoming S/PDIF link, you have the wrong DAC.
In my experience, PSU arguments are usually made by those selling PSUs.
the record spot said:Overdose said:the record spot said:Exactly, or at least, normally, the TV wouldn't be - I've streamed via my Sony telly without a hitch many times. However, it's restricted to PCM, so if you want FLAC, or whatever, you lose out.
Some might be, but I imagine not all. Mine (Sony KDL-CX523) doesn't for one. Tried it off USB stick and nope. The specs make no mention of FLAC either. So while theoretically TVs might be capable, it's not offered as standard.
tomlinscote said:If you don't mind me asking have you tried the Sonos direct into the power amp stage of the amp, ie using the sonos as the pre amp, and if so was it really that bad?
I only ask as this is what I do, Roksan power amp and MA RS6 and it sounds good to me (esp BBC radio 6) not tried putting the CD player through the line in, but do feed the TV through it and it sounds fine too.
Tommo
