Review Hifi Vintage Ltd. Avoid!!
Deafdog68
6
Hi
This is very simply relating my experience with HiFi Vintage Ltd.
I purchased a NAD 7140 receiver for £198 and the first time I unplugged the headphones the socket broke. What follows is their reply when I informed them of this. I am a tolerant person..except when people are rude and I find their response extremely rude and unhelpful. So beware this company.
" Hello, it looks like the socket was damaged while plugging in the headphones.
Before shipping, the amplifier was tested and there were no issues with it.
The equipment you purchased is from the late 1980s and requires some delicacy.
Unfortunately, mechanical damage is not covered by the warranty."
I'm afraid this is the risk you take when buying old second had gear when no servicing has been carried out and no returns policy stated. These traders have acquired this unit likely from a house clearance or such like and are merely selling it on. When talking about 80's gear, even if the unit works ok, it will likely not sound that good if no servicing/cleaning work has been done. You need to find a repair service that is familiar with vintage gear who can service and repair it for you. Sorry if that is not what you wanted to hear.
Reactions: nopiano
Hi Steve983, thanks for the comment but the company stated it was fully serviced and tested and they do have a reasonable sounding returns policy, check out their website. This is why I am rather angry that when I sent my email saying the headphone socket was broken they sent the surly reply quoted. They have now agreed to look at the item as I have requested a refund though whether they will agree to a refund is another matter. Had they replied as I would have expected e.g. "sorry to hear this please return the item and we will remedy the issue" I would have been perfectly happy even with return postage costs. But to imply a 40 year old amp was absolutely fine, tested, serviced etc up until the point I unplug the headphones once, just once, is in my mind unlikely. As they are now engaging with me I will hide this post (if possible)
Ah fair enough, if they've serviced it and then you find a fault - just plugging headphones in should not be a problem. Pleased that they are now responding to the issue, good luck with it.
Ironically both of you are right, in a way. You are entitled to think that if it has been checked and serviced then it should be good for a while. They are are also correct that, even if they checked the headphone socket, they’ve no idea how carefully or clumsily you’ll use it. Everything that breaks was ok on the previous use, by definition! And forty year old plastics will be brittle and prone to breakage - no service can remedy that.
I hope you get it sorted.
Reactions: Steve983
Unless I get a complete report on what exactly was done during a 'service' I don't think it's worth the paper (not) written on but that's just me. Any reputable company will provide this. Loads of stuff on the bay apparently serviced ... .
Plugging something in and see if it powers on is not a service but it is a test.
However, even a complete service can not always foresee material failure which can occur over time.
If you are happy with the product and subsequent offer of refund why not ask if they can repair it for you?
There's a lot of used hi-fi sellers out there, many of which are just "working" from home and cashing in on the boom in used audio at the moment. There's another one that was mentioned on a Facebook group recently who is extremely rude and abusive to customers, before and after sales. They don't care about you, they probably don't care about audio, they just want your money.
thanks all for your comments..I am just shocked by their attitude really..had they suggested any reasonable way of amicably resolving it i wouldn't be posting here...but to simply say "it's old and you broke it" is very poor...ok, now to try and hide this post until I hear back from them when they get the amp back to look at
Even if a listing says 'recapped' or similar, I'm very wary and investigate below the surface, because some people genuinely know how to do the work properly, using quality parts and with the skills to get it right, and some are just playing at it in a shed or on the kitchen table. Sometimes work has been done to 'improve' an item, but that takes it away from original spec and you don't really know what you are getting.
Second hand hi-fi can be a great way to achieve high performance levels for less, but the risks need to be navigated with care.
Just an update on this...it gets funnier..Hifi Vintage agreed to look at the item so I sent it back to them, at my expense...so they took it apart, photographed the broken headphone socket then reiterated I used too much force plugging in the headphone adapter (or removing it..their "Forensic" electronics engineer didn't specify which one nor exactly how many Newton's of force above the design limit of the socket I apparently applied)...so they are sending it back to me still in the broken state...i find it hilarious that they a) didn't offer to fix it originally even though they state there is a 30 day warranty, b) didn't offer to fix it when they took it apart to check it and c) have been thoroughly obnoxious throughout... I am sure there are many reputable 2nd hand HiFi dealers out there..this company is not one of them!!
'The equipment you purchased is from the late 1980s and requires some delicacy'.
That part from their original response tells you all you need to know about the company.
It's hard to imagine how anyone could come up with such a ludicrous comment.
It wouldn't be too easy to use too much force to insert a plug.
However, I was slightly concerned about your mention of an adaptor - their additional length can really add to leverage on the socket....not saying that was the case for you - but something or someone (previous owner?) has caused unusual damage.
The fact that it's an older product, may mean a socket replacement shouldn't be too difficult - if you know anyone handy with a soldering iron.
As someone that worked in service / returns departments for years, I don't think much of the lack of customer service in your case.
At least the company has got the advert they deserve.
Sorry to hear that, you were right the first time: AVOID.
Did you buy this unit on E Bay?
Hi Steve, no they have a website, just Google Hifi Vintage Ltd. It looked professional plus they sell some very expensive items. They were very helpful before i bought the item..but i guess they would be before i parted with my cash
