Hello - hope someone can help me identify a problem. About 6 months ago I bought a Pro-ject 1.3 turntable for a knockdown price from Richer Sounds (it was only lacking a needle and an anti-skate weight which I got off the internet). I set it up as best I could according to the instructions, but have always had an intermittent problem that either or both of the channels become quiet and crackly. They come in briefly if I tap the top of the tone arm but this doens't really resolve the problem. I have replaced the cartridge and needle and still have the same problem. In fact it is possible that the problem is even worse having done so. Does anyone know what the problem could be. I wondered if it might be one of the following;
(a) Incorrect needle alignment - I don't really know how to use the two-point protractor, but it seems that with so many degrees of freedom (the rotation of the turntable and the movement of the tone arm) that wherever your needle is, it will hit both points on the protractor!
(b) The Amp - I am using an old Marantz amp, but I don't think it is this, as surely tapping the head of the tone arm wouldn't make a difference. Also, the CD, and auxiliary channels are fine.
(c) Loose connection in tone arm. Not sure if this is possible, but it's the only other thing I can think of.
I shoud say when it works, it works beautifully - particularly through my Wharfdale Diamond 121 speakers!
Any suggestions?
thanks
Andre
Any suggestions?
thanks
Andre
