HELP WITH MY S550
Hi, have just purchased the s550, and have ordered a w5500, just a quick question, how do i link it up with my wireless router, i have read the instructions, but it doesnt seem to be any clearer, it is my first blue ray purchase, and it probably is dead simple. Also is it worth getting a new power cable? if so any recommendations for about £15, as i dont fancy spending £40 on the copper line
I'm not sure about this but I think the only BD player at the moment capable of wireless connection is the PS3. I think you would need to connect the player to the router with an ethernet cable.
Kids are screaming, otherwise I would double check the instructions................
Can't be done wirelessly out of the box as standard, you need a wireless bridge (like this one) to attach it to a wireless network. Otherwise, as the old chosen one says, just run an ethernet cable to it.
If its anything like the S350 its a doddle with the ethernet cable from the router, just follow the instructions.
Hi.
I use one of these (http://www.broadbandstuff.co.uk/product_info.php?products_id=501) on my Panasonic BD50, it is a doddle to setup and is cheaper than the linksys.
Hi
I have the S350 which I set wirelessly up using one of these ( http://www.ebuyer.com/product/132431) it has lots of user reviews and some even go as far as telling you how to set it up!
By reading the advice I had it plugged in and updating the firmware on the Sony in less than 10 mins. However Linksys are a quality make, it depends on what you want to spend. As I say it was a dodle to set up and works fine.
Bc.
Perhaps I should clarify, I'm not necessarily recommending the Linksys, I've never used it. Just using it as an example of what you need to hook the device up to a wireless network.
thanks it doesnt sound to daunting, any views on the power cable?
