- Aug 10, 2019
- 2,556
- 5
- 0
Hi all.
Right, i've just got a replacement for my 2 month old LG 32LG5020 (same as the 32LG5000 methinks) and it's fixed the jagged-edges problem my last LG had. The new one seemed fine until I booted up the ol' PS3.
Straight away on the menu screen I noticed that when I flicked from menu to menu, the icons (which move quite quickly in case you've never used a PS3) seemed to go brown when they moved, before they settled still.
I booted up Home and looked at that, and whenever there's high-contrast movement, i.e. someone running past the 'camera', there's a whopping great yellow shadow, almost as if the yellow element to the pixels is a little behind the other pixels. I'm pretty damn sure I didn't notice this on the one I took back.
Anyone come across this before, am I imagining this, is there a way to fix it or should I just take the new TV back again?
Any help hugely appreciated. I'm just growing to like this TV after a shaky start, but honestly, if this can't be fixed on the box itself, I'm gonna try for my money back I think (I've had the TV just under 2 months).
Please respond, is this a unique-to-my-tv thing? I've tried googling but can find anything on the keywords I've used.
Thanks,
Alex.
Thanks,
Alex.
