Hi - I have a Denon AVR 6400 which I have had for a while which was powering my Tannoy speakers in 5.1 configuration.
I have recently upgraded my speaker package to Monitor Audio Gold 200 (L&R) 150 Centre and FX rears (With a velodyne SPL1000 sub)
While looking through the manual for something else I saw that if you are running 4 Ohm Speakers (which these are) then I should switch the AVR to 4 Ohm mode.
I have done this but to my surprise the amp is now running at about half the power.....even though 4 ohm speakers require more power to be optimum...so i am a little confused.
Am I correct in thinking that the 4 Ohm system is to protect the AVR as it is not really powerful enough for my speakers ? and if that is the case I really need to be looking at external amplification for all my channels.....or risking it in 8 ohm mode ?
What I don't want is to be massively compromising on quality just to save the AVR, because then it would have been a total waste of money investing in such good speakers...
