No offence, but that list is a bit unrealistic. I only know of Commonwealth because they made broadcast decks in Oz, don't think you'd find them here. The EMCs again are broadcast decks and you're unlikely to find them except at stellar prices. Same goes for the Garrard and the Thorens TD 124, which also has the disadvantage it can't take MC cartridges. If you can find a decent SP10 for reasonable money then you're not only lucky but will be able to sell it for a profit. The Revox are linear trackers which require a special kit if you want to change the cartridge. There are lots of others in your list which are as rare as hens teeth and command top dollarfor what they are.
Nothing wrong with advising second hand, but something like the Technics SL1200 or 1210, assuming a non-DJ one, or belt drives like the Thorens TD 160 or 150, Ariston, Linn, Systemdek etc are robust decks that perform well and are easy to find. There's also a stack of info about them on the web, including the manuals.
Me, I'd go new, something like the Clearaudio Concept, and get the dealer to set it up, after which you can forget about fiddling until the day comes when you need to change the cartridge. It'll also sound as good if not better than most of the decks mentioned in that list.
