Help needed for setup with Q Acoustics 2010
I'm looking to buy Q Acoustics 2010 speakers after reading the best buy review, I currently own a Sony KDL - 32W4000 and a PS3, I use this for my music and think i should buy some speakers. I have NO idea what i need to setup the speakers, can some one tell me or have a link to a page so I can learn what the hell I need?
The 2010 will need an amplifier to power them for starters. Did you have a budget in mind - you might be better off getting some small powered speakers or Q's own Q-TV instead if your budget is limited?
have you tried the Tv outs, or headphone? do you get sound being output after the image, i.e. no sync between pic and sound?
there isnt anything wrong with the sound or sync im just thinking about buying some speakers to play music etc through but am on a budget and need advice
we have to know if you need an AV amp with lipsync correction,but if you can coonnect a stereo amp to the tv and still get pic and sound in sync, then a stereo amp can be had cheaper.
i have no idea what your asking, this is how much is need help, i am literally clueless but any info on the tv or ps3 should be on the internet.
Understood. The 2010s are great, but it'd be difficult to buy them and a half-decent amp and remain in budget without dipping into the potentially choppy waters of second hand amplifiers. I'd be more inclined to buy something like Audioengine's fabulous A2 or A5, which both have built-in amps and will sound substantially better than your TV for not much money.
you can get a yamaha rxv365 od sony strdh500 for around 150 and 2010 for a bit more , and that would be in yout budget.
or maybe better the pionerr vsx 519 that also has 5.1 ins and zone 2 out, so it can be used in the future as a pre amp if you get a better amp.
or get a cheapo amp and a pair of floorstanders , mission m33is or q accoustics , cheap as chips , add sub , centre and sats when you can ?
thank you very much JohnDuncan i now have a much better idea of what to look for and will probably get the A2's anyway
