Hi
First of all, thanks everyone for all the forums which have helped so far, but in the end I have just got my self a little confused.
Basically I have decided to set up a hi-fi system in one place in my house for optimum sound quality, a place to listen to music.
Want to listen to CDs, occasionally plug the system via stereo jack into a an iPhone/iPad for internet radio (no DAB or FM signal here) and also play music from them. And I have an airport express to use airplay again from iphone, ipad and my MacBook.
I currently use a NAD C 300 (but also have a Nad C 3020i amplifier), with M71i Mission speakers, and a very basic Toshiba DVD player (used as a CD Player). The system is in a large room, although the sitting area of this room is like a normal size room, just not walls all around it. Some soft furnishings but not much mostly wooden floor and ceiling (granite wall on one side), and in one part of the big room there are 7 metre high ceilings. It's an old wesleyan chapel in Cornwall. Quite open plan.
So what I would really like some help on is....
1)
-Is the NAD 300 or 3020i better, I think the NAD 300 sounds a little muffled in comparison? But picked this one over the 3020i because of the remote control (bit lazy, very willing to swap back if people think 3020i is superior)
2) The big question
-Am I better off improving my current system, by buying a better CD player (a entry level marantz or similar) - or look into a cheapish DAC unit to take all the digital inpouts.
OR
-just retiring the AMP and Speakers to a secondary room and going for a whole new system such as the new MCR 610 Marantz (or Marantz 603) with bundled Q2020i speakers - and solve everything in one swoop??? Would that in reality just be loads better than all of above, do the all the same functions but just do them better.
I don't have a budget as such, just hate falling for the consumer fetishism trap and buying something unneccasrily.
And I think I want a good sound but possible not sophisticated enough at the moment to warrant top end gear.
would really appreciate help on this one.
best
Andy
:help:
1)
2) The big question
OR
best
Andy
:help:
