- Aug 10, 2019
- 2,556
- 5
- 0
My budget is up to $1500 and the current candidates are B&W 705, CM1, 683, 685. Because the local store don't have whole of them to illustrate to me, I think I have to go to another bigger city to listen. So, that's why I want to get some of your opinions here.
I found the most reviews on 705 is very good, but few are not because some people think that the 705 is too bright and they think it might have something to do with it's too high and unusual crossover of 3700Hz between tweeter and woofer. So my first question will be: does the 705 really so bright? I will mainly be listening classical music including symphonies, concerts/sonatas, solos, operas and so on.
The second question is: if 705 is too bright, how about the CM1? Will be a problem its too small dimenstions? I think it will be hard to image presenting a symphony from such a small box, but I am not sure about it.
Third: How do you compare 683 to 705 or 683 to CM1? which is better? And, does the 683 bright or soft?
Last but not the least, What's the producing country of these models? I heard some of which are made in China but don't know more about that.
Thanks in advance.
Thanks in advance.
 Facebook
Facebook Instagram
Instagram
