Help in choosing a system
gmouttou
Hello All,
I currently have a Pioneer HTP 071 and looking to sell and buy a better one.
My criterias are :
1. Need a Mini Hi Fi which can hopefully play a DVD
2. To be bluetooth enabled to play songs from my phone
3. A nice receiver with wireless 5.1 speakers as the house I am moving to is not feasible to have wires
4. A small turntable to play vinyls
5. Budget : £750
Any advise please.
Thanks.
try adding a 1 to the budget. *biggrin*
seriously you are expecting a lot from your budget, are you looking at new or used equipment.
Maybe Curry's or pc world sell an all-in one yamaha/Sony or the like AV system? They probably also do some cheap USB turntables.
Depending what outputs your TV has you could look at Sonos PlayBar or PlayBase to get you started. Both offer great sound, can be added to in the future with Sonos Play powered speakers and a powered sub as and when funds become available. If you are serious about having a good AV/Hifi experience then I wouldn’t buy a complete system on your budget because you will almost certainly be disappointed.
yeah, sonos is your best bet
it’s wireless, however could be over the budget if buying new but you can start with mentioned playbase and add more spekers when funds allows; with sonos you don’t need av receiver
you can get new dvd player for around £30 and connect to your tv
do you have vinyl collection?
+1
what's funny about that?
https://www.whathifi.com/denon/d-m41dab/review no dvd player
or if you can find one used https://www.gumtree.com/p/amplifiers/nad-c-717-dvd-receiver/1216200087 dvd player
Turntable https://www.whathifi.com/audio-technica/lp3/review
Speaker suggestions
https://www.whathifi.com/dali/spektor-2/review
https://www.whathifi.com/q-acoustics/3020/review?oq=3020&src="textfield&aq=3020&type=review&pos=top"
My personally choice https://www.whathifi.com/mission/lx-2/review?oq=LX-2&src="textfield&aq=LX-2&type=review&pos=top"
Changing amp to a Onkyo A-9010 (or nad 3020i) https://www.whathifi.com/onkyo/9010/review (no cd/dvd drive)
Turntable rega rp1 https://www.whathifi.com/rega/rp1/review
Q acoustics 2010i https://www.whathifi.com/q-acoustics/2010i/review (monoprice,micca you name it q acoustics 2010i is my low budget speaker choice)
Theres about 210£ for a dvd player and som decent speacker cable and interconnects,hdmi cable for the dvd player
Speaker suggestions
Theres about 210£ for a dvd player and some decent speacker cable and interconnects,hdmi cable for the dvd player
Did you read the OP? Mini hi-fi, no speaker cable.
Speaker suggestions
Gasolin, Have you actually heard the system separates you are proposing, all working in harmony together? Or are you simply adding up the value of a series of well reviewed boxes which adds up to the OP’s budget?
If the speakers are wireless, they must be self powered. They each will need a power lead and access to the mains.
Not sure how that will go with the need for no wires?
i have or had most of the speakers (mission lx-2,q acoustics 2010i,3020i) and i own the nad mini dvd system and a nad 3020i
My experience is that nad goes well with q acoustics
Her you go http://www.klipsch.com/products/r-15pm-turntable-pack you just have to buy a dvd player
https://www.amazon.co.uk/Klipsch-R-15PM-Powered-Monitor-Black/dp/B01A7J534G
Unless max is one power cord
Personally i won't suggest any 5.1 since you get better sound from a stereo setup
totally wireless, battery powered home cinema built using portable speakers? I’m not sure if anything like that exist?
gmouttou said:
Hello All,
My criterias are :
5. Budget : £750
Any advise please.
Thanks.
Arcam movie Solo 5.1 £1000
(Covers 1-2 and some of 3)
2nd Hand TT Depends on how big your collection is?? but say £100-150
(covers 4)
As for the 5.1 wireless speakers? Pass
Over budget, but food for thought!
Yeah I don't know about this either, I don't think he/she has explained this well.
I think they want a normal amp but wireless speakers only?
Hopefully they will post back, sounds a instresting system!!
Haha, this is not so far fetched. His previous two posts were a good while back and no replies to either. I don't think he'll be coming back to this thread either.
