Heck its gone again !!
Hi All, I have a Cyrus 3 amp with PSX-R. Had it for a good while and seviced 24 months ago by Cyrus and 8 months ago had to have some other fixes for it. I was advised this is the end for it, if it goes again.........Yep, right channel not working on any outputs. So, its either one more fix, cheaply, or what would be a replacement ?
Speakers are P4, Marantz CD63 SE. Room size 12x12, solid floor. Listen to the usual P Collins Rob Williams Eagles Kylie etc
What route would you suggest
Thanks in advance guys..
Gordon
If you like the Cyrus 3, but don't want to risk it again, Bartlett's Hi Fi in London had a Cyrus Straight Line amp for £150 a few weeks ago.
Worth considering as it's from the same era, will take your power amp as is, and is considered by some as being a better amp against the 3 with a simpler internal design, no additional circuitry for remote controls, etc.
The Cyrus two (Last model, with flip switch on/off) was actually sonically superior to the Cyrus 3, so id say get one of those with a PSX. Definitely with a PSX. It adds 20 watts per channel and makes a hell of a lot of difference. The 2 on it's own is weedy.
I had them up until a year ago and thought they were great. Brilliant detail and clarity, if a little bass light.
Hi, Thanks guys, I will look into your suggestions..
Gordon
