Headphones up to 30 pounds
dubi95
Hi guys. I'm looking for reasonable headphones up to 30 pounds, preferably on-ear (or over-ear if better) mostly for rap music.
dalethorn
2,222
Did you check the reviews on WhatHiFi?
dalethorn
2,222
MajorFubar said:
These are what you need for rap: If find normal headphones, noise cancelling or otherwise, don't block it out nearly half enough.
Excellent. These should block most of the gunshot noise too, in the U.S. at least.
MajorFubar
690
8
ae235
I find normal headphones, noise cancelling or otherwise, don't block it out nearly half enough.
MajorFubar
690
8
dalethorn said:
MajorFubar said:
These are what you need for rap: I find normal headphones, noise cancelling or otherwise, don't block it out nearly half enough.
*biggrin*
mchander
28
Hello
I want to buy earphones
Both are within my budget on ebay
But i am not able to decide which one shall i go for
Both are whathifi award winners
Any suggestions
dalethorn
2,222
mchander said:
Hello
Any suggestions
You never really know until you try. You buy steak, but you get hamburger. Pick one. If you get lucky, c'est la vie.
