Graham_Thomas:Mickgw:
I have a Little Dot III amp, i'm using with the 650's, works really well Ditto with Senn HD600s.... Hi Graham, how are you finding your amp?
I'm really pleased with mine and i'm happy i changed to the Senns, the AKG's are awesome but the Senns are just better with the type of music i listen to, does changing to the mullard tubes make a big difference? i dont really want to start going down the road of analysing the sound to the point of not enjoying the music anymore, i believe you can get upgraded cables for the HD650's but as i previously mentioned i'd only change if it was only going to make a noticable difference.
Thanks,
Mike
