hi can anybody help with this problem i have a panasonic ae4000 projector a 50 s10 panasonic plasma and a panasonic 750 blu ray recorder also sky hd they are connected up as follows 75cm chord active from sky to a chord hdmi matrix and 75cm chord active from blu ray to matrix then a 3m chord active to plasma and a 10m chord active to projector the sky and blu ray work fine on the plasma but i am having problems with the proj the sky comes on for a few minutes and then goes off and the blu ray does not come on at all if i go into the blu ray set up and turn hdcp off then i get the settings screen on the proj but it says that i cannot watch anything because hdcp has been disabled if i bypass the box and plug them in direct they are both fine could this be a problem with the box or the proj as i am at a loss i have been on 2 days also the sky box isbrand new as they replaced my old hdbox as it would not work on the 10m cable 75cm ok 3m ok 5m ok 10m no way sky could not underrstand this and sent an engineer out to test and when i showed him he agreed and changed it
any help would be great
thanks for reading
dash
thanks for reading
dash
