HD TV Watching with or without HDMI connector - help!
I recently bought a Sony KDL40 X4500 and hooked it up to my digital TV decoder. I have digital TV, including a number of HD channels. The TV is hooked up to the digital TV receiver/decoder with a simple scart. I don't find watching the HD TV channels all that impressive to be honest (dont see much difference with regualr digital tv), and was wondering if this had anything to do with the fact that I use a scart...
Is it worth getting an HDMI cable to hook the TV to the decoder, or will this not make musch difference? Or is it just a matter of changing the settings on the TV? (It is currently on factory settings)....
Same question for hooking the TV to my DVD (and maybe soon Blue Ray) player....
Thanks for your help!
HDMI cables can be bought for very little money (try Amazon) so it makes sense to try one - I am sure you will see an improvement compared to scart.
You can always upgrade to a more expensive HDMI cable at a later date.
There are many debates on here about cheap vs expensive HDMI cables so I wont add to it here.
Start with one costing a few ££ so you have nothing to loose.
Thanks Haystak-
It isn't so much a matter of ££ (or ?? in my case) but I simply didnt know if the "poor" quality of the HD channels (when compared to HD displays in stores) was due to the cable or the TV settings....
Even if I have the intention to buy a cheaper cable I'll probably end up walking out the store with something expensive - know thyself
But from your reply I can see it probably is more of a cable issue...?
You cant view HD through a scart so no wonder you dont see any difference (In fact they probably look worse than normal SD)
You NEED a HDMI to view in HD
If you have a THX dvd (terminator 2, start wars etc) then use the THX setup menu to set brightness and contrast (And sharpness if still connected via a scart cable)
Heres some general settings ~
Select MOVIE mode (Usually best overall settings to begin with for brightness and contrast)
Then set these ~
Colour: 50
Col Temp: Neutral
Sharpness: 50
Noise Red: AUTO (for Analogue TV), OFF for all other sources
MPEG N/R: HIGH (Digital TV, Sky (direct), OFF for all other sources
DRC Mode: Off (have not experimented with this yet)
Black Corr: Off
Adv Cont Enh: Off
Gamma: Low
LED Dyn Control: Standard
Auto Light Limiter: Off
Clear White: Off
Colour Space: Standard
Live Colour: Off
White Balance (have not tweaked yet)
Detail Enh: Off
Edge Enhancer: Off
Motion Flow: Clear
Film Mode: OFF
Game/Text Mode: OFF
XV Colour: Auto (Sky, Amp), no option for other sources
Photo Colour Space: SYCC (for Sky, Amp) ""
Colour Matrix: Auto (for Sky, Amp) ""
RGB Dyn Range: Auto (for Sky Amp) ""
Actually ~ these are probably better settings (Until you can set brightness, contrast, colour and sharpness yourself)
Picture Mode: Custom
Backlight: 2
Contrast: 85
Brightness: 51
Colour: 48
Col Temp: Neutral 0> may change this after prof. calibration.
Sharpness: 50
Noise Red: Off
MPEG N/R: Off
DRC Mode: Off
Black Corr: Off
Adv Cont Enh: Off
Gamma: Off
Clear White: Off
Live Colour: Off
White Balance: (Set some values by eye, but need to do it properly
using proper calibration tool and software, will report later)
Detail Enh: Off
Edge Enhancer: Off
Motion Flow: Clear
Film Mode: OFF
Game/Text Mode: OFF
XV Colour: Auto
Colour Matrix: Auto
RGB Dyn Range: Auto
KC1976:
There arent any HD channels on UK Freeview, or are you based in Europe??
Last time I checked the UK was still part of Europe
But yes, I am based on the mainland and have approx 6 or so HD TV channels (some "regular" national channels and some international documentary channels such as HD National Geographic)
KC1976:
Thanks- and what's the best way to do this (as a beginner)?
ÿ
The best way is to pay a professional to do it for you. An ISF certified calibrator will have specialist equipment to measure what your TV is outputting against accepted standards. They'll also know which controls to tweak in order to make your TV match those standards with your sources and your room's lighting. Costs about £250. I've never heard of anyone regretting the expense.
