Harmony One £69.99 on Amazon
Spooky!! I was just this second looking for the best price on one of these, come back on here and you've done it for me.
Cheers!
Argh! SO annoying. Just bought mine from amazon, like last week, and tried to use the harmony1 code but it had just expired! Now this! £25 off would have been very nice to save... :(
matengawhat
695
15
18,895
reorder and return the new one but use the original invoice from amazon with the higher price through your account - have done this many times since amazon stopped their 30 day price match
Coolio! Thanks, Marineman, Just ordered mine. Hopefully will be able to have all the functions that my amp remote has but work much better (had to manually program it for my BT Vision box, then lost it all when I changed the batteries)! Then get some cool macro's working..
marineman:Amazon price 94.99 use discount code HARMONY2 and get £25.00 off. Mine is on its way.
Thanks marineman - been looking at these for some time. Just ordered one. Hopefully will gain points from the wife when seven remotes replaced by one.
Thanks for that just ordered one, been following their price since before X-mas £25 off sealed it, cheers!
Just set up my new Harmony One, its really good, especially the macros, saves a lot of button pushing. BUT the software is a bit iffy, it times out a lot. Anyone else had software problems?
