- May 27, 2009
- 582
- 0
- 0
Feel The Burn- While it is most important to burn-in cables upon purchase in order to dispel gasses trapped in the manufacturing process and abate the initial, high electrical charges often found in new cables, there is something to be gained from routine maintenance as well. If cables are left unused for a prolonged period of time they become stagnant. And even with everyday cable use, electrical equipment experiences current leakage, imparting a charge onto your cables. By having your cables treated with the Nordost’s Vidar on an annual or bi-annual basis, you are conditioning them and allowing the charges to neutralize once again.
Cure Static Charge- Anti-static treatment is a must. Used on both audio and AV gear, this spray helps to fight the deceptively dangerous, slow build-up of static charges. Static charge can do everything from flatten perspectives to inhibit the dynamics of a sound system. Simply spray a small amount of Eco 3X onto a cloth and wipe the area around speaker drivers. You will begin to reveal a more relaxed and natural soundstage. We especially recommend using Eco 3X in the winter months when static build up is more prevalent.
