Group test of 2010 HTIB systems
Hi Andrew,
I am very interested in the group test of the new HTIB systems in the [size=3 face="Times New Roman"]£[/size=3 face]600-700 price range, like:
Samsung HT-C6930W (3D capable),
Samsung HT-C7550W,
LG HX995TZ (3D capable),
LG HB965TZ,
Sony BDV-E870 (3D capable) and
Panasonic SC-BT735 (you have already tested it, but how it compares to the others?)
Are you planning such a test (or similar)?
Also, I would very much like to know their abilities with stereo music.
Thanks in advance for your reply,
Goran
Hi there, i was looking at getting a all in one system a few weeks ago and posted a topic on here about it, and was told that there was going to be a group test of all in one systems in the next issue so that might help you.
At the price you are looking at, as i found, out going the seperates route will give much better results all round.
hope that helps
Cookie Monster
132
Hi Craigy P,
Not wishing to go off subject but:
Does your Sony S370 BD player tie in well with your Sony STR-DN1000 and Jamo's?
I have the same setup but i am currently using a Panny BD player that has a solid forceful sound even in bitstream. My PS3 suited the amp better but has just 'died'! ( 3rd in as many years) The Sony S370 would make a very sensibly priced solution if it all synchs together well.
Advice appreciated.
KInd Regards,
Cookie Monster
Any answer, Mr.Everard?
* Thanks for the suggestion craigy p, but I am only considering all-in-one system due to reasons which are not useful to be explained in this thread.
Best rgds,
Goran
Andrew Everard
1,878
Yes, there's a group test in the new issue, with subscribers now and in the shops on Wednesday: includes JVC TH-BD50, LG HB965TZ, Panasonic SC-BT73 and Samsung HT-C6500.
Just purchased a Sony KDL-40EX503 to replace an ageing 32" CRT, now want to match this up with a Blu-Ray player and potentially a home cinema system, so looking to What Hi-Fi for some advice.
My budget is limited (£500 tops), so wanted to know if matching up a Sony BDP-S370 (£100) with a home cinema amp and speakers, or going for a Home Cinema System (eg Sony BDV-E370, £400, or Sony BDV-E870, £450) is a better option?
The recent Home Cinema Test didn't have any Sony system in the test, so how does the 5 star system like the old model BDV-E300 compare with the new model and the competition?
Also how does the actual Blu-Ray player part of the all-in-one system compare with a standalone player, using the BDP-S370 as a benchmark?
