Having had a Rega arm for years I’ve never needed to ground anything but I’ve just bought a new tonearm and created a problem.
I connected the ground wire to the Phono stage and we get a hum through the speakers so I put another wire between Phono stage and the TT chassis and the sound was still there.
Thinking there may be a problem with the arm I fetched my Audiolab 8000A amp out as it has a phono stage in it (The Caspian does not) and connected the arm and ground wire direct to this and the problem disappeared so there is nothing wrong with the arm.
Next I connected the arm and ground wire to my Phono stage and the Phono stage to the tape in on the Audiolab and the problem reappeared.
As a final check I connected the arm and ground wire direct into my AV receiver Phono input and the problem disappeared. So there is definitely nothing wrong with the arm.
I have now set up as follows the leads from the arm go into the Phono stage and the Phono stage feeds the Caspian amp, and I have connected the ground wire to my AV receiver and the problem has disappeared. The lead was not long enough to reach the Caspian unless I alter my rack.
Is there anything else I should have tried? Is the fault with my Phono stage? Or am I being paranoid and the ground wire is ok where it is?
I might try and borrow a spare Phono stage from someone I know next week and see if that works.
I hope this makes sense to anyone who reads it.
