- Aug 10, 2019
- 2,556
- 2
- 0
I am using an Onkyo TX-SR 806/ Sky HD.
Ok I now know that Sky HD don’t send DD via the HDMI (god only knows why not thought) this is causing me a major problem as follows.
I set the Onkyo to accept CBL/SAT via HDMI from Sky, no problem there, the picture is great but the sound is only in stereo.
So I then connect the optical cable from sky into the Onkyo and then tell the Onkyo to accept Sky’s DD audio signal via Optical.Problem is that the amp seems to only want to process the crappy stereo audio signal that it’s receiving via the HDMI cable once it’s connected, and prioritises it over the DD optical signal and in effect just ignores it, hence I still just have stereo.
However the set up within the Onkyo set up menu appears to be correct. Any help would be greatly appreciated, I note that both Andrew Everard and Clare Newsome have both commented on similar problems and hope that they can help with this one, please????
NB: I know that the Onkyo is getting the audio signal via Sky, as if I plug the HDMI directly into my Plasma and the Optical into the Onkyo I get full DD from the amp, but as soon as I plug the HDMI back into the Onkyo the sound drops back to Stereo.
