Question Gemini Man 4K
michael hoy
Have any of you purchased the 4K steel book version from zavvi. If so have you had any issues with the 4K disc.
Mine will not play on my OPPO 203, the standard Blu Ray however does.
Zavvi are going to replace mine.
Deleted member 2457
I have had a few problems with 4K discs over the years, Crouching Tiger Hidden Dragon was one I can remember. There were others too though.
Deleted member 2457
Hi Gel,
This is the first disc I have had an issue with in years.
As I said Zavvi are going to replace, I have not come across via google anyone else having an issue so maybe a faulty disc.
Hi, yes I have had a few faulty discs too.
Deleted member 2457
I also used to have problems with dust or fingerprints on one of my old Oppo 203’s kept freezing!
Next one I bought was fine, mind you the first one came out right at the beginning before the firmware updates.
michael hoy
Update:
Zavvi replacement still does not work for the 4K UHD disc.
I have had a response from OPPO support.
They advised to set the player to UHD 24 for the video output, I also had to set it to source direct.
The film will now play. Noted that this film is recorded at 60 fps and not a 24 fps.
