- Apr 10, 2008
- 189
- 0
- 0
Finally setting up my cinema system after moving house, with a new cantilever tv stand to fit all my equipment on. But I have a few questions hopefully someone can help me with.
The THX website states that the front L/R speakers should be at 45deg from your listening position....clicky, angled directly towards the listening position. My problem though is that there is not enough room to get 45deg, will having a reduced angle ruin the sound/performance?
My viewing distance is 9ft from my 42" Pany plasma, so to get 45deg and spacing correct I would need 4.5ft between the front left speaker and the center of my tv. My problem though is that I have just under 5ft from the center of the screen to the left side wall ( looking towards the tv ).
If I place my Mission M33i floorstander at 4.5ft distance I will be almost touching the side wall and it would be positioned right in the corner of the room. Add in the 45deg angle and I would imagine all I will hear is alot of boomy bass. The M33i speakers go down to 44Hz and the low end is suprisingly powerfull, a recipe for disaster. I don't even have a sub, although I would like to get one when funds allow.
How close to the side wall can I position the speaker to avoid overblown boomy bass?
Should the front L/R speakers be angled directly towards the viewing position?
Any idea what distance they should be from the back wall? Is 30cm about right? Obviously I will need to experiment but a good starting point would really help.
Other speakers are Mission M3C2i and M3DSi via a Denon 2105 amp, Chord Carnival Silver Plus speaker cables with fronts bi-wired.
The room is aprox 10ft wide by 20ft long if thats any help, due to the room layout the tv can't move to any other location.
Thanks, lot's of questions there
EDIT: I did have a look through the video section but couldn't see one on cinema speaker setup, unless I missed it which is more than likely.
