- Oct 18, 2010
- 13
- 0
- 0
Hi David,
Been trying to reach out to you on another post. Guess you didnt notice.
I am really sold on the PMC Twenty.22's. But havent heard it with my M3i. Not possible to lug it and test there. Therefore wanted to check with you on your opinion on pairing these two. What do you think considering that you could have actually listened to them. Is the M3i less matched to drive the 150W PMC? How is the bass sounding? Is it tight/short attack and delay? If you feel against this pairing what other options should I look at? Also if you like it do you think I could wall mount the Twenty.22's? Or do you insist that I use the stand mounts?
Please help. I am sitting with the amp and temp speakers and I have heard the PMC's. They are way way above my budget but now I am planning to go EMI on them ( you can sense deep lack of regard to anything in my life right now but to get some these decent pair of speakers )!! So your input will be very valuable here. Kindly help.
S
S
