- Aug 10, 2019
- 2,556
- 5
- 0
After reading a post on how to configure Foobar2000 to use Asio drivers I have been tinkering with the program and it's various plugins. I stumbled across one called convolver which allows you to modify the sound by adding effects and eq etc. The forums I stumbled on seem a little technical and I am not sure how you configure your own "impulses" so I began downloading some. I haven't exactly found any that meet my needs, which is to beef up the bass somewhat. Does anyone here have any experience with this plugin and if so, which impulses do you use and where did you get them from? If you created them yourself, can you offer me any tips on how to go about this? It appears this little plugin has a lot of potential, I just don't know how to go about unlocking it!
