AlmaataKZ said:
6th.replicant said:AlmaataKZ said:
+1
If the FLACs are 24-bit, IME it's best to convert FLACs into AIFF using Max, then once the AIFFs have 'appeared' in iTunes, use it to convert to ALACs. (Don't forget to transfer the AIFFs to Trash.)
If Max is used to convert 24-bit FLACs into ALACs, the latter will end up as 16-bit.
