Question Fixing speaker cables
peterkt
I’ve just purchased some QED X25 speaker cables which I now need to run around the room. I’m going to use some d-line trunking between the floor and skirting board but I need to run the two cables around a doorframe. I was wondering whether some ‘invisible’ double-sided adhesive tape might work - would be interested to know if anyone has used something similar or would welcome any other suggestions?
Gray
I ran 2 core cable round a door frame, using correctly sized cable clips.
Probably sounds to you like that might be a bit rough-looking.
That's what I thought. But it was surprisingly unobtrusive. In fact, I forgot it was even there.
(Along the top part of a flat-edged frame it is actually invisible).
