Fix or replace
Hey guys well the law of the s0d has struck again, as some might remeber I bought myself a luvly new LG plasma a few weeks back which is great but low and behold my bedroom set (samsung le32a656a) has starting going sideways it switchs itself on the flicks between input channels and also has mad moments when im watching.
I contacted Samsung but as soon as I said its 2 years old they gave me a number of a reapir centre local and hung up (cheers samsung)
I have read its a common issue but can find any details so im currently trying a remote control fix suggested to me but other then that its a £75 fault find cost then whatever the cost is to repair so if anyone has any suggestions that would be great failing that can anyone suggest a good 32" set it needs to be decent and it will be for gaming mainly with dvds and sky im not on a budget so no cheapo tesco sets I dont mind paying.
Looks good although I did fancy an LED if I did replace mind you saying that I cant take advatage of the flatness as I still use scart which pushes the set right out from the wall.
