If you are experiencing issues, have you tried contacting Denon support? Firmware updates are sometimes only released to specific customers that complain about the issues that the update resolves, before they go GA (generally available).
Usually not worth it to install a non-GA firmware update unless it's supposed to fix an issue that is really bothersome for you.
