- Aug 10, 2019
- 2,556
- 5
- 0
I have finally decided to invest in a blu-ray player and fancy the Sony BDP-S560 or the Sony BDP-S760, but I'm unsure whether my Home Cinema will be able to cope!!
The current set up I have is very unsophisticated and low budget as it's an all in one-but is as follows:
TV: Sony KDL-V26A12U
DVD: Panasonic DMR-EZ27EB
SATELLITE: Samsung Sky+ HD
HOME CINEMA: Sony DAR-RD 100
As the home cinema is an all in one the amplifier is contained within the sub-woofer, so the only way to connect my DVD recorder and Sky+ HD box is by using the Optical Digital cable at the rear of the sub woofer, and since there is only 1 cable (out) from the sub woofer I have to switch it between my DVD and my Sky box depending on which I'm watching at the time!! It's a pest but isn't really a problem.
1) The sound that I currently get from the Home Cinema is great (well I think so) but will I be able to use the same set up when I buy my blu-ray player??
2) I think both the Sony blu-ray models I was looking at have an Optical Digital output, so will I be able to just plug in the optical cable from my amplifier/sub-woofer the same way as I do at the moment??
3) If so, will my amplifier/sub-woofer be able to understand the signal it's receiving and decode it if necessary??
I would greatly appreciate any advice or answers you can give me. Thanks in advance!!
