All my digital music consists of downloads from iTunes. Since I’m playing back through my iPhone/iPad would I get any benefit from an external dac if hooked up to a decent hifi?
Using 3.5 socket and cable to aux inputWhen you say 'hooked up to your hifi', do you mean a receiver with a dac inside? If so, then no, because your dac won't be able to connect to your phone. Your receiver could, via bluetooth, but it's dac will be included on it as a feature. A standalone dac can cost more than your receiver did, and sound unbelievable, but you would need a way to send music to it via spdif or usb.
What's your current set-up?Using 3.5 socket and cable to aux input
So currently no possibility to add a DAC.Using 3.5 socket and cable to aux input
I could use the lightning connector instead with a dacSo currently no possibility to add a DAC.
He could use a Audioquest Dragonfly DAC with the appropriate wiring from his phone. Nobody mentioned a receiver, and definitely not Bluetooth.When you say 'hooked up to your hifi', do you mean a receiver with a dac inside? If so, then no, because your dac won't be able to connect to your phone. Your receiver could, via bluetooth, but it's dac will be included on it as a feature. A standalone dac can cost more than your receiver did, and sound unbelievable, but you would need a way to send music to it via spdif or usb.
Ok let me explainHe could use a Audioquest Dragonfly DAC with the appropriate wiring from his phone. Nobody mentioned a receiver, and definitely not Bluetooth.
A Dragonfly can cost under £100 and most amplifiers cost way more than that. I’m afraid for your first post, I don’t find your contribution very helpful at all.
Yes, that’s what I understood. I suspect it’ll give little of benefit, but you should be able to find a retailer - or specialist like Futureshop - who’ll let you buy or return if you don’t like.Ok let me explain
all my music is from iTunes therefore as downloads they are not top quality. The iPad obviously has a dac which I currently use to play back through my (good quality) stereo using a wired Headphone connection to an aux input on the amp
if I bypass that by using the lightning connector and a dac will I get better quality or is it a waste of time?
www.audiosciencereview.com
Never understood why Chord make their products look so wacky. Always put me off.
