Ex Demo TV?
Garth Man
156
Had a few scratches and a chip on my TV when first delivered , so i had the company replace it with no problem the other day
Now the Original TV came with a protective tape around the picture frame to obvously stop marks scratches etc
The replacement didn't have this tape at all, so I was a bit confused by it
Also the TV had a preference to Home/Shop setting when turning on the first time. Shop being brighter than the Home setting
Does this sound a bit suspect??
The TV is a Pana 42THPZ85
ah maybe I'm being paranoid though I probably forgot doing that the first time
The tape thing did baffler me though...
cheers
If your replacement did not have the protective tape and all those lovely stickers a new screen comes with then there is a possibilty that it is a factory re-pack (ie a set that was sent back for repair and since been fixed) as opposed to a Brand New never used unit. Some companys opperate in this way when replacing faulty units, EG Sky do this if you unit develops a fault.)
The original TV had the protective tape round it but not the stickers.......
So bloody annoying, just want the TV i paid for!!!
Anyone think its worth mentioning to the company I bought it from?
If you are happy with this replacments condition and its working properly then I would not bother but I would personally give the set a inspection all over checking say screw/bolt heads on the rear to look for signs of if the rear panel has ever been removed as if this is the case it would definatly point towards a factory re-pack.
The Dixons group had a reputation for selling returned items as new (someone bought a 'new' PC that had the previous owner's files left on the hard drive)!
