Eltax Liberty 5 Floorstanders.
Hi, I'm new to the Forum and this will be my first Home Cinema Set Up, a Philips 36PW9607, and Pioneer AX3 Amp and DVD Player which I've yet to purchase. Lots of questions to ask, but for now, I need some advice on placement of the Liberty 5 Floorstanders, how far apart, do they need to be turned in towards the listener and filling them with sand. I've not got a lot of space, probably about 3ft either side of the TV to spare. Any advice will be much appreciated....Thanks.
Regards....Dave.
If the eltax are to be your home cinema speakers dont set them to far apart. No need do toe them in my my opinion.about filling them with sand Im not so sure about..
How close can they be next to the TV as they are not shielded, is a foot ok?
Dave.
good question.If you dont see any colour change on the screen I guess that would be fine.
I have my tangent millennium 200 ( guess they are not shielded) right next to the crt tv .I see no difference on the image.
It's a Phillips 36 inch CRT, I'm sure I heard they should be a minimum of 2 ft from the screen.
