I've been experiencing some sort of hum from my Pro-Ject Debut Carbon Esprit SB (DC). I don't know if it has always been there, but the last week I've been playing at a louder volume level than before because I got a new amp *biggrin*
It's not constant, but the hum increases when i bring the arm towards the center. It isn't motor hum, since it also occurs when it's not spinning.
I've tried changed the cables, checked the gound, even changed my mains block, but nothing seems to work.
It does stop completely when I disconnect the power to my turntable. The hum is only slightly audbile when I touch the outer connection (negative?) from the power supply *scratch_one-s_head*
Could this be a faulty PSU or is it more likely a grounding issue?
