HELLO,
I HAVE BEEN WATCHING BLU RAY DISKS ,WHICH ACCORDING TO THE DISPLAY BAR ON THE SONY BDP 550 ARE BEING OUTPUT AS: 'DTS HD AUDIO MASTER 3;2/1 48 HZ '. THE BIT RATE IS AT 19 -27 . THERE IS 5:1 SOUND COMING THROUGH WHEN THE DISPLAY STATES THIS . MY OLD SONY AV AMP IS CONNECTED VIA 5 COAXIAL INTERCONNECTS (LFE DIVERTED)INTO THE 'MULTI CHANNEL DIRECT CHANNEL' . ALL SEEMS WELL BUT CAN SOMEONE SUPPLY THE 'AUDIO SETTINGS' FOR THEIR SONY 550 BDP SO I CAN CHECK . THAT IS IF ANY OF YOU ARE USING THE 'MULTI CHANNEL AUDIO CONNECTION' METHOD ! I DO NOT WANT TO START MESSING WITHOUT SOME GUIDANCE.NEITHER DO I WANT BE BE GLIBLY ENJOYING 'DTS HD AUDIO' WHEN IT MAY ONLY BE BOG STANDRD DTS. I WANT TO BE SURE THE BDP 550 IS DOING THE ON BOARD DECODING.
